eg. exg a3,d0 add.l d2,a5
eg. add.w (a2),d3 movea.b (a0),(al)
eg. cmp.l (a2)-,d5 movea.b (a0)+,(al)+
eg. add.b 10(a3),d3
eg. movea.l 20(d0:w,a2),a2
eg. add.l 0x7100,d3 add.l 0x4la713c,d3
eg. move.l 100(pc),d3
eg. movea.l 10(d0,pc),a2
eg. add.w #0xl2f4,d3
b (byte) w (word) l (long)to the instruction.
instruction operand action comments. mnemonic size ----------------+--------------+-----------------+----------------------- EXG 32 bit Rn -> Rm exchange registers LEA 32 EA -> An load effective address MOVE 8/16/32 EAs -> EAd replaces LDA,LDX,STA,STX etc. in the 6809 the general move instruction SWAP 32 Dn(hi) <-> Dn(lo) swap register halves MOVEM 16/32 EA -> Rn ... Rm move multiple registers Rn ... Rm -> EA etc.
ADD 8/16/32 EA + Dn -> Dn CLR " CMP " DIVS 32/16 signed divide 32 bit/16 bit DIVU " unsigned divide " MULS 16/32 signed multiply 16 bit x 16 bit MULU " unsigned multiply " NEG 8/16/32 2's complement SUB " TST " compare with zero & set flags etc.
AND 8/16/32 OR " EOR " NOT "
ASL 8/16/32 ASR " LSL " LSR " ROL " CARRY is not included in ROR " the rotation ROXL " as above, except the X bit ROXR " is part of the shift registe
BTST 1 bit BSET " BCLR " BCHG " test & change bit the Z flag reflects the state of the bit tested
ABCD 8 add BCD operands SBCD 8 subtract NBCD 8 negate all results are extended to 32 bits
Bcc where 'cc' represents one of the 16 testable conditions eg. BGT, BLS, BMI etc. the offset may be 8 or 16 bits in length. DBcc as above, except ....... decrements the specified register, tests and branches if condition met. BRA BSR JMP JSR RTS etc.
An E signal is continuously generated by the 68000, which does the same job as the E signal of the 6809. Since 6800 peripherals do not generate DTACK, a 6800-type bus cycle is timed with respect to the E signal instead.
How does the 68000 know when to execute a 6800-type cycle?
Address decoding is used to reserve some memory locations for synchronous devices. When an address in this range is used by the 68000, the address decoder sends a VPA (valid peripheral address) signal to the 68000 which causes it to synchronise with the E signal.
Since the E signal is continuously generated, it can be in any phase with the instruction execution cycle. Therefore, when VPA is asserted, the 68000 waits until the E signal is high and then goes low - marking the start of the E clock cycle.
Thereafter, wait states (SW) are inserted by the 68000 until the end of the E clock cycle, when the 68000 cycle terminates in the usual (asynchronous) way.
The address decoding can be as simple as in the diagram below, where synchronous peripherals are addressed when A23 is high.
